Suggestions?
Have an outside tap that cannot be shut off during the winter months. When it gets cold outside I can plug a heat tape in to prevent it from freezing.
Recently installed the EDS OW-server to monitor temperatures and the vera plugin, works great
Plan is to create a scene when the temperature goes below 3 degrees C. the outlet turns on and the heat tape comes alive. Like wise another scene to turn off the outlet at temperatures above 5 degrees C.
Question is when the temperature reaches the trigger temperature of the scene will the scene keep firing as the temp keeps dropping or rising or do I need to care if it keeps on firing or does it just fire once?
If the trigger only occurs once at the desired temp I was considering of adding this code as the temp toggles between 3 and 3.1 degrees for example. The scene will not refire if active within the last 2 min. Again will the outlet really care if it gets the command to turn on again when it is really on.
local result = true
local now = os.time()
if (LastTime) then
result = now - LastTime > 120
LastTime = now
return result
Thinking it just really boils down to saving CPU cycles in my vera lite and reducing RF in the house.
Thanks for any comments or suggestions.
Should not hurt to send an ON command to a switch that is already on.
Of course you need a second scene to handle turning it off as well.
If you want to make sure you only send 1 command … you can use the PLEG with two conditions.
They will only fire the actions once when the condition is satisified:
i.e.
HeatOn Temp < 3.0
HeafOff Temp > 4.0
You do not need to have an outdoor thermometer … you can use the Weather Plugin for temperatures in your area.
I actually do this as well … but for me it’s turning on a circulation pump 15 minutes/hour when the temperature is below 35F. This is to circulate water between the Rain Water Storage tanks and the House (Some pipes exposed). A side benefit is that I also run the water though the filters.
Thanks Richard for the comments. Already have the WX plugin but since I have my new toy the OW-Server :slight_smile: I thought I would use it since I have a temperature sensor already attached to the faucet. In the winter I have a cover over it and with the heat of the house it seems to stay a little higher than the ambient temp outside. Never used PLEG but it looks like a good time to take a look at it. Time to search for info. Thanks
