Hello I have Suc SIS:YES PRI:NO
How do I get the Vera2 back to primary?
If I reset my Zwave network will I lose everything or can I reload from a good backup
This all happened when I did an upgrade from 2.78 to 3.20
I now downgraded back to 2.78
Bruce
Did you run the [tt]Hack to convert 2.78 to 3.20[/tt] after the upgrade to 3.20, per the instructions?
Yes I ran the hack per instructions
I see. You said you have [tt]Suc SIS:YES PRI:NO[/tt]. Is that currently, while on 2.78, or (also) when you were on 3.20?
That line should have looked different in 3.20; perhaps the firmware upgrade to 3.20 didn’t take?
Running ‘the hack’ (while on 3.20) is the only way I’m aware of to force the role back to [tt]PRI[/tt] without resetting Z-Wave etc.
Perhaps ask tech support to have a look?
Thank You I ran the upgrade again to 3.20 and ran the hack
I’m now SIS:NO PRI:YES :
Bruce
