Stuck on Running Lua Startup
Hello,
I have installed the Caddx app on my Vera 3 and had no problems. Then once day when I went into my UI5 and it was stuck on “Caddx NX584 Security System[43] : Running Lua Startup”.
I am unable to use any of the functions of the app. I cannot arm or disarm. I uninstalled and re-installed the app but I ran into the same problem.
Has anyone run into this before? Can anyone please help me troubleshoot.
THANK YOU
UPDATE
I changed Baud rate to 38400 and the problem is FIXED!!!
[url=http://code.mios.com/trac/mios_caddxnx584/wiki/WikiStart]http://code.mios.com/trac/mios_caddxnx584/wiki/WikiStart[/url]
Open the Vera UI and navigate to Apps >> Develop Apps >> Serial Port Configuration.
If the serial port is not in the list, restart Luup.
Set the Baud to match the setting on the other end of the serial cable. The default is 38400.
Optionally you can rename this port in the Name input box.
Save.
