Firstly I love this plugin, great work!
Secondly my NX-8E has 2 of the NX-1710E installed with swipe/strike locks.
I am not 100% familiar with the panel, but would it be possible to add a feature to control these strikes from the plugin?
I am 0% familiar with the term “swipe/strike lock”. That doesn’t bode well for support, but you could educate me.
The plugin is generally able to do anything that you can do from a physical keypad. In your lesson you could address how a keypad features in the control of the lock. I could then see if there’s anything similar in the serial control interface.
Edit: I went and found the programming manual for the NX-1710E. It looks like it acts autonomously, that the usual behaviour is for a card swipe to activate the onboard relay to unlock the door. The state of the relay is not exposed to the serial interface, so you’re out of luck if you want the plugin to see even the swipe event, let alone which user it was. Additionally it doesn’t look like you can control the relay from a keypad, so nor will you be able to control the relay from the plugin. The associated zone that you have to attach to the door will appear as a normal zone, so you’ll see the door opening and closing.
You might luck out with messages in the panel’s event log. I didn’t see anything relating to door lock relays but the accuracy of the event log documentation has been called into question so I wouldn’t rule it out.
To verify all of this you could collect a Luup log (with Debug to Luup Log turned on) while you swipe and see if there’s any chatter related to the plugin.
Ok, so there is some output in the DL900 software unfortunately I can’t seem to cut and paste the long out of my VM
I will do as you suggest now, is there an email address I can send the log too, I am not keen on pasting it here…
