Strange SM103 behavior
I’ve got two sm103 door sensors on my garage doors. One works fine. It trips only when the door is opened or closed.
The other one is fine until it trips. Then it just keeps tripping. I have a scene that sends a VeraAlert message when the door is open and when this door opens, I get a constant stream of “The main garage door is open”. I have to go disable the scene trigger to get it to stop.
I checked all the settings for the two sensors and they are identical.
Here’s the main difference but I don’t know how this could cause the problem:
  1. The one that keeps tripping doesn’t have batteries and is wired directly to a 4.5v DC power adapter
  2. It is wired to a Seco-Larm external contact switch.
The setup actually works fine from a UI5 perspective. The sensor icon appropriately shows tripped/not tripped when the garage door opens and closes and the garage door plugin also works fine. The only issue is that any scene that is triggered when the sensor trips just keeps getting executed forever.
Any ideas? I’m tempted to remove the power supply and try with batteries but I just can’t fathom how the power supply looks any different to the device than a set of batteries.
Is this a new installation or is this a previously working installation that has now failed?
Have you looked at the log to verify that Vera is actually receiving flapping trip/untrip signals? You can watch your log here http://vera_ip/cgi-bin/cmh/log.sh?Device=LuaUPnP
If it is not, I would look to see if I had conflicting automations, one scene or PLEG fighting another.
If you confirm that Vera is indeed receiving a flapping signal, I would then check the power for polarity issues or failing supply especially if it is a new install.
I would then check the contact switch with a multimeter or test light to make sure that it doesn’t have a failed reed switch. If you’re not up to that test method, disconnect the external switch and test the SM103 behavior with a magnet against the internal reed switch.
This is an existing installation. However, I added the power supply and external door sensor.
I was getting poor battery life and poor signal quality with the sensor mounted to the track.
It was the logs that prompted me to post here. It’s clearly bouncing constantly. The scene is just a trigger/wrapper for luup code which has always worked.
I did some experimenting this weekend. I brought the whole setup inside and hooked it up at my desk so I could watch the log. It worked perfectly. The only difference inside vs. outside is that I have about 10 feet of wire between the the sensor and external switch. Testing in my office, I had the pigtail of the switch (about 1.5 feet) attached directly to the sensor. Everything worked fine.
I went and got a long length of the wire I used to span the 10 feet in the garage and problems started. Simply hooking the wire up to the motion sensor caused it to trip and start spewing endless open/close status. I didn’t even have the external switch wired to the wire. It was just the wire with bare ends at each end. I’m not sure it’s the length of the wire or poor shielding or what. The wire is 4-wire phone wire.
Great! You found the problem.
I would have expected your setup to work. But since it doesn’t, I’d relocate the SM103 closer to the contact and shorten the wire.
[quote=“Z-Waver, post:4, topic:177697”]Great! You found the problem.
I would have expected your setup to work. But since it doesn’t, I’d relocate the SM103 closer to the contact and shorten the wire.[/quote]
Tried some 18AWG in wall speaker wire and it almost worked perfectly. Out of probably 5 open/close sequences it only went nuts once. However, that one time is one too many. It causes me to have to kill the VeraAlert app and disable the scene.
I ended up extending both the power supply wires and shortening the Seco-Larm wires. It seems to working fine now and the signal strength appears to be good enough. It just looks ugly that I’ve got the power, window sensor and switch spaced 5 feet apart from each other.
