Strange child device - Qubino Flush 1D Relay
Hello,
I have just successfully installed Qubino Flush 1D Relay (ZMNHND1) to control my garage door and after the inclusion there is parent device “Temperature”, which is OK - Qubino supports temp sensor, which I don’t have but it also created strange device “GET_LANG” (see screenshot) which has nothing in its configuration (Device Options, Control - everything is blank).
I don’t know what it is and how to get rid off it, I have tried to delete it, but it recreated itself again.
BTW: Controlling of garage doors works perfectly with this Relay, it is also powered by 24V spare outputs on my Garage main controller.
Thanks for advice!
I had the same with my Flush 2 Relay - I just hid it using the luup.attr_set(“invisible”, 1, DEVICEID)
Thanks, that is what I needed to know - it is normal behaviour, so nothing bad happened by me :slight_smile:
