Hi all! I’m on UI5 (1.5.622 ) running on Vera3.
I’ve struggeled the past few days with some luup-code not working as expected. I believe I experienced a lot of strange and unexpected behaviors so I did my first debug session. I found several lines in LuaUPnP.log indicating memory leaks. I deleted a PLEG device that I’ve been working on recently and things started to look a bit better. I still may have some problems to solve before I can start to make any further development.
Here are the log entries ordered by time that I find suspicious
[ol][li]03/15/14 15:40:21.203 GetSunriseSunset error#1 sunrise: 1394774769/2014-03-14 06:26:09 sunset: 1394817171/2014-03-14 18:12:51 midnight: 1394838000/9611972 <0x2b651000>[/li]
[li]03/15/14 15:40:23.254 luup_require can’t find veraUserTemplateDefinitions LEAK this:184320 start:184320 to 0xce7000 <0x2bf85680>[/li]
[li] 03/15/14 15:40:46.101 luup_log:7: InitD: 1394860845 : 1394894446 : 1394903700 LEAK this:8192 start:1294336 to 0xdf6000 <0x2cb85680>[/li]
[li]03/15/14 15:42:14.622 LEAK this:4096 start:1298432 to 0xdf7000 <0x2bd85680>[/li][/ol]
(My device no 7 was the “Day or Night” -plugin, Version: 1.8, I deleted it now.)
About luup_require can’t find veraUserTemplateDefinitions it seems to be related to VeraAlerts plugin so I’ve posted that question in the proper thread already.
Any ideas how I can solve my problems? What are normally causing memory leak problems on my Vera?
