Im having trouble getting to grips with the multiswitch plugin. Coukd some explain in a step by steps idiots guide how I use the switch. I have installed the plug, but cant work out what to do next. Could someone explain gently how I get it to control something. Once I’ve got through a working example Im sure I could pick it up. Many thanks.
You need to use LUA or PLEG to do the actual automation.
The multiswitch is just the user interface.
Login to your Vera. On the dashboard go to the APPS tab.
Locate the MultiSwitch app and click the word ‘MultiSwitch’ next to it.
On the window that opens click the Help tab/ It will load the manual for the MultiSwitch
This link may work directly https://docs.google.com/file/d/0BykZKwGsCBsAaTJiWnNKLWdvR2c/edit?pli=1
Thanks guys much appreciated.
