I’m nervous about posting this topic since there are only two others in this forum – makes me think I’m doing something wrong, but it doesn’t seep appropriate to tack on to an existing, 2-year-old, 39-page thread.
I’ve been troubleshooting a problem for days. I’ve got a Vera Lite v1.5.532 with the v2.45 plugin. I have configured my AD2USB to use address 23, which has been enabled in my Vista 20P. Everything works, except when the system is armed, the “Status:” line constantly bounces between “Armed” and “Ready” every few seconds. I have also noticed that when the system is disarmed, the “Chime Mode” toggles on and off (dark blue and light blue) at the same frequency.
I started poking at the LuaUPnP.log for VistaAlarmPanel messages and found that when the system is armed, I see messages like “ARMED STAYMay Exit Now 35”, with the number decreasing every second or so (obviously, this is the countdown). In the middle of these countdowns, I see another message “DISARMED Ready to Arm”.
The ARMED messages look like this:
50 01/26/13 16:14:46.535 luup_log:46: (VistaAlarmPanel::processIncoming) Incoming data = '[0011000110000000----],010,[f70600871010008028020000000000],"ARMED ***STAY***May Exit Now 10"'. <0x2de51680>
50 01/26/13 16:14:46.535 luup_log:46: (VistaAlarmPanel::getStatusFlags) Active flags: ARMED_STAY, CHIME_MODE <0x2de51680>
50 01/26/13 16:14:46.536 luup_log:46: (VistaAlarmPanel::getPartitionState) Got Alarm='None' for partition 1 (device #47). <0x2de51680>
50 01/26/13 16:14:46.536 luup_log:46: (VistaAlarmPanel::getPartitionState) Got ArmMode='Armed' for partition 1 (device #47). <0x2de51680>
50 01/26/13 16:14:46.537 luup_log:46: (VistaAlarmPanel::getPartitionState) Got DetailedArmMode='Stay' for partition 1 (device #47). <0x2de51680>
And the DISARMED messages look like this:
50 01/26/13 16:14:42.125 luup_log:46: (VistaAlarmPanel::processIncoming) Incoming data = '[1000000100000000----],008,[f70000080008001c08020000000000],"****DISARMED**** Ready to Arm "'. <0x2de51680>
50 01/26/13 16:14:42.126 luup_log:46: (VistaAlarmPanel::getStatusFlags) Active flags: READY <0x2de51680>
50 01/26/13 16:14:42.126 luup_log:46: (VistaAlarmPanel::getPartitionState) Got Alarm='None' for partition 1 (device #47). <0x2de51680>
06 01/26/13 16:14:42.126 Device_Variable::m_szValue_set device: 47 service: urn:micasaverde-com:serviceId:VistaAlarmPanel1 variable: ChimeMode was: 1 now: 0 #hooks: 0 upnp: 0 v:(nil)/NONE duplicate:0 <0x2de51680>
50 01/26/13 16:14:42.127 luup_log:46: (VistaAlarmPanel::getPartitionState) Got ArmMode='Armed' for partition 1 (device #47). <0x2de51680>
50 01/26/13 16:14:42.127 luup_log:46: (VistaAlarmPanel::getArmMode) current ArmMode = 'Armed', new ArmMode = 'Disarmed' <0x2de51680>
50 01/26/13 16:14:42.128 luup_log:46: (VistaAlarmPanel::setPartitionState) Set ArmMode='Disarmed' for partition 1 (device #47). <0x2de51680>
50 01/26/13 16:14:42.129 luup_log:46: (VistaAlarmPanel::getPartitionState) Got DetailedArmMode='Stay' for partition 1 (device #47). <0x2de51680>
50 01/26/13 16:14:42.129 luup_log:46: (VistaAlarmPanel::getArmMode) current DetailedArmMode = 'Stay', new DetailedArmMode = 'Ready' <0x2de51680>
50 01/26/13 16:14:42.129 luup_log:46: (VistaAlarmPanel::setPartitionState) Set DetailedArmMode='Ready' for partition 1 (device #47). <0x2de51680>
Attached is an excerpt from the log that shows the panel READY, then ARMED STAY until a few seconds after the countdown expires, then DISARMED again. Arming and disarming for this log was done with the Vera.
