The image below shows a green box, this is flashing every second while the condition is true, in OpenLuup. The exact same condition in Vera does not do this. Is this a bug? Everything is still working.
Flashing means the condition is timing something. Did you test a condition with timing options on the openLuup side as well? Delay reset, sustained for, that kind of thing…
Edit: also make sure you are testing with the same browser. The animation is CSS and browser-dependent.
Everything was the same in Vera and Openluup, same timings and browser, The only difference was Vera/OpenLuup.
I just thought it weird that it did not flash on vera, but flashing on OpenLuup. At first i thought i had done something wrong.
