Hello,
I noticed I haven’t set up yet a static IP adress on my vera lite ( my vera 3 allready has been set up like that) , but there is a part of the setup I don’t understand.
The Ip adress the vera lite should be: 10.0.0.11
subnet mask: 255.255.255.0
gateway: 10.0.138 (that?s my modem)
DNS: not sure what to insert there, also my modem?s IP adress?
But than , There is also a LAN part, which have allready been inserted with
IP adress: 192.168.81.1
HUH, what is that? what do I insert there ?
For info:
modem = 10.0.0.138
main vera3= 10.0.0.10
slave vera lite should be 10.0.0.11
DHCP server is 10.0.0.20 (Since modem cannot assign fix Ip adresses)
many thanks,
Cor
attached a screenshot of the manual settings of vera lite.
