One of my pleg devices has stopped wanting to start, saying startup LUA failed. I have not added anything to startup LUA. I was configuring some new conditions at the time and suspect I have done something to brick it but as I can now not start it to change anything, I am a little stuck! The last thing I did was to add a condition that was taking an input from a satisfied condition in another PLEG device. Any advice on how to go forward?
I managed to fix it by cutting and pasting the conditions from advanced tab and modifying manually then pasting back in. Not quite sure what caused it to have issues though. One thing I did wonder - I named the input for the PLEG device condition the same as the condition it was looking for. ie: Input
HLSs1Double Special Automation has satisfied condition: HLSs1Double
(Special Automation is the name of the other PLEG)
Is there some restriction around reusing the names that could cause it to complain?
Do you have the before/after of the corrupted data ?
It might help me to find the source of the problem.
There is no problem having the same names in different PLEGs … or referencing one from the other as you have shown.
