Startup Lua Failed after auto upgrade to 4.0
Today my Vera Lite auto updates to 4.0 of the VeraAlerts plugin. My current status at the top of my Vera says Startup Lua Failed. I tried to reboot my Vera and it still says the same thing. If I go into the Notification Configuration of the VeraAlerts plugin it said updated 31 items so I thought this would fix it by doing a save but it still says Startup Lua Failed. If I go into the profiles and try and add a new profile it says “Device not Ready” Any idea what I could try next short of just removing the app and re-installing it? If I re-install it would I loose all of my custom message overrides I have created? Thanks again Richard for creating a wonderful plug-in an app for the community. Have you ever thought about asking for donations or making the app paid for all your hard work?
I figured out my problem after doing a search on the forum and finding indianl’s solution. I clicked on the VeraAlerts plugin, then clicked on Advanced. I went down and deleted everything from the “Profiles” variable. There was a ton of things in there so I deleted it all and did a saved which made the error go away right away. I then had to just go back in and re-label my phones and enable them again for notifications. Thanks
