Just started on my Vera (lite with latest firmware) and downloaded today the virtual switch plugin.
Whenever I open the plugin I get an “stack overflow at line 0” error. When I try to change the name Virtual Switch, and hit Add, it does not save.
What am I doing wrong?
I know this is an old topic, but I’ve run into this also, and since there was no response posted here (or anywhere else that I can find), I thought I’d post the results.
This error, “Stack overflow at line 0” appears to be unique to IE 8. I’ve tested now with Safari, Mozilla (Firefox), and IE 9 and 10, and I’ve not received the same error; only IE 8 running on XP appears to give the error.
Hope this is helpful to future explorers…
(If you’re still running XP, I suggest using Firefox instead of IE 8 )
Melsman
Yep, solved via another browser
