SRT321 Room Thermostat With VeraLite
Hi All
I Have VeraLite With Firmware 1.5.622 and I have SRT321 Room Thermostat when I want to control it from veralite I received this Error ( Failed, waiting to retry when the node wakes up )
Please have a look to this video
Now a one week no any response
Hello
أرسلت من GT-I9505 الخاص بي
http://forum.micasaverde.com/index.php/topic,4575.msg110866.html#msg110866
Check like the 4th or 5th post from the end. You have a setup issue.
Could be a dip switch problem.
Since its battery the device is sleeping unless you press a button. Its not waking up to receive comma from vera.
If you take a look at this guide, it shows how to set this device up in a step-by-step way.
http://www.vesternet.com/resources/application-notes/apnt-20
It sounds like you have not finished configuration, or the wake-up period is set too long.
Mark
Vesternet
