Hello,
When I use the URL below to find the image from a “camera”, the test page shows the now-playing image correctly. But after I am done including the camera, I get a “miscellaneous” device that Vera does not treat as a camera. Has anyone else seen this behavior?
[tt]http://192.168.1.100:9002/music/current/cover.jpg?player=00:04:20:xx:yy:zz
[/tt]Thanks,
Mark
Not that specific error but the fix might work When I added an IP Video 9100A manually, all I had to do was copy/paste “D_DigitalSecurityCamera1.xml” into the “advanced” tab "device_file category (which was blank) and the camera then showed up correctly
