SQ + V2 + UI4?
I’ve unpacked the Vera 2, and will probably jump off this cliff later today–our Vera 1 works great, and we’ve never moved off UI2, so I hope we’re not headed off into the weeds here.
We use Square Connect a lot. Just wanted to make sure that it’s still going to function with a V2 running UI4? I’ve tried hunting through the fora, but haven’t seen this exact question answered. I’m sure it’s there somewhere.
SQ + V2 + UI4 == good to go?
–Richaed
The current version should work locally on your LAN but if you want remote access you’ll have to wait a little while.
The SQ guys are rushing as quickly as possible to get a new version into the app store that will work with cp.mios.com (for UI4) and also findvera.com for previous versions as well as a bunch of extra new features.
