I have a CA3500 I am using for some lights that is randomly turning on. It’s as if I have Ghosts!
Anyway I always turn this device on at the same time with another. I looked through all of my scenes to make sure I didn’t have a misplaced “turn on” but none found (would be cool if you could do a reverse search along the lines of “Where used” to scrub all the scenes and triggers for debugging purposes).
I set up a notification/log just to see what was going on. The log indicates a trigger as the type and source of the turn on action. Does this mean Vera initiated the turn on? Or could it be the device just spuriously turned on and Vera detected it?
I was having trouble with some of the load devices triggering the load sense feature of the CA3500 but I have isolated the load with a relay so all the CA3500 sees now is a relay coil and two 60W incandescent bulbs.
