Sprinkler as security feature
Does anyone who has Etherrain know if I could write code to get the water to turn on in response to a z-wave connected motion sensor? Also, does Etherrain work on wifi, or does it have to be wired in w/cat?
Yes you can - as any other scene
There’s no wifi, but my guess this below should be able to fix it
http://www.focalprice.com/CN0008G/Mini_Portable_TPLink_TLWR702N_150_Mbps_WiFi_WLAN_USB_Wireless_Router_Green.html?SSAID=82989
Adding wifi would increase price by about $40, and I think the creator decided it would be way too much
Could also bridge it with one of these (cheaper, but bigger):
http://www.monoprice.com/products/product.asp?c_id=105&cp_id=10521&cs_id=1052102&p_id=8071&seq=1&format=2
I was thinking of doing this exact same thing. What are you using for a motion sensor outdoors?
Interesting idea … I was not previously aware of the EtherRain device.
Someone would need to create a plugin or at least extract/document the API details so that it could be controlled by Lua code fragments attached to a scene.
There already is and has been an EtherRain Plugin forever :slight_smile:
http://code.mios.com/trac/mios_etherrain-controller
oops … had the wrong focus when I did a forum search!
The other option i’m thinking is going with a fortrezz valve to hose with sprinkler head and have motion open the valve, or removing Vera from the equation altogether and getting a scarecrow sprinkler on Amazon.com (check out the user submitted photos for a good laugh) which may not be as pretty but will save $500 and a day of installing…
Sent from my SPH-D710 using Tapatalk 2
