I have a problem with a detector Everspring sp103
vera is in reconu but blocks waiting on wakeup and thus the parameters are not complete in advanced
missing variable tripped example and doc goes into the detector tripped and therefore no action has reacted
I try to remove it and return to Vera but it gets stuck on waiting wakeup and if I support 2 times the tamper communication and he moves well but it makes me special association and not tripped varaible in the configuration menu
you have solutions?
thank you
