Sony AV - HTTP GET commands via LUUP
After reading a similar thread (http://forum.micasaverde.com/index.php/topic,39728.0.html ) related to DirecTv I have successfully created scenes to turn on/off the DirecTv unit.
Now I am trying to find the codes to control my Sony AV receiver. It is a Sony STR-DN1080.
I’ve searched with no luck and dabbled with wireshark, also no luck. If anyone has a simple list of the commands and a sample get command that would be absolutely awesome!
Thanks,
I also have this question for the same AV reciever.
Maybe there are other AV recievers using the same IP/HTTP commands?
What did you get with wireshark? I got my Pioneer working partially after using an Onkyo plugin (eISCP)
