Sonos/Whole House/Vera Question
I am getting ready to start building my whole house audio replacement (currently using 30 year old Nuvo system) and wanted to ask a question before I started. I have three rooms in my house that will be next to impossible to run in ceiling speakers and volume controls so I am 95% sure I am going with a hybrid system.
I am looking at the new monoprice whole house kit for the rooms that I can wire pretty easily and using a Sonos system for the rest. For those of you who have a Russound or similar whole house solution and use a Sonos for the front end, do you get any noticable delay between any Sonos rooms and any rooms with your whole house kit.
I would use the sonos system as a source for the whole house while playing the same sound on Sonos speakers in those rooms that cannot be wired. Will I get a noticable lag in audio or will they be in sync?
I know that there is currently no drivers for the monoprice kit, but was kinda interested in trying to write them myself if nothing comes out by then.
Thanks,
While I can’t answer your question I can say that the Mono price system looks to be exactly the same as the HTC mid system which many people would like a plug in for. More power to you!
I had a similar scenario a few years back, and soon will again so I was just looking at this topic, so here are my 2 cents:
I’m into my 8th year with Sonos. The Sonos keeps itself in sync very nicely. Sonos does not come with the ability to configure a set delay. Where most folks run into trouble is dumping good Sonos signal into some (not all) digital units that try to do funky stuff that introduces delays. So you’ve got two points of potential delay: the Monoprice, then each (potentially) of the three Sonos zones. If that Monoprice is analogue, should be no problems. At least I hope so as I will soon be dumping good Sonos signal into a Russound.
Will you be using Connect Amp, Play 1/3/5 powered speaker units (almost zero chance of delay) or Connect to a receiver of some sort - that last scenario could introduce delays. Are those three zones for ambient or critical listening?
This thread on thead on the (very good) Sonos forums might shed some light:
http://forums.sonos.com/showthread.php?t=20699&page=2
In past lives I drove a Harman Kardon 7xxx (forget which model sorry) in parallel with Sonos kit with no delay problems, then later a Harman Kardon 345?( unsure again sorry). Lately I’ve gone with whole Sonos (Play 1/3/5 and Connect Amp for built ins) set ups for usability and audio quality (open to subjectivity, I know). What I like with the Sonos vera plug in is the ability to direct audio / text to speech directly to a Sonos zone with defined volume without having to worry about secondary volume or switching controls.
I’m not yet set up so yet to experience the Vera / Sonos / Russound set up, emailing back and forth with the Myro:bridge guys.
Hope this helps. And enjoy the tunes!
Quick Update:
Got the Sonos ZP80 (from 2007!) hooked up via analogue outs into the Russound.
Issue#1: You actually need to define a source in the Russound.
Issue#2: the Russound control apps is only Windows.
SO after finding a Win7VM I had lying around, installed the App:
Minor Issue #3: USB Connect requires USB drivers, so let’s do over network
Minor Issue #4: App doesn’t do discovery (I mean heck, who does that?). And the MAC address on back of Russound wasn’t the same so grabbed IP address of the keypad. Will make static IP address later today.
But with 5 minutes to spare before guests, have Sonos driving Russound, no sync / timing issues whatsoever.
In the basement have a Play 3 at the bar end, a Russound zone in in the middle family room, then Play 5 in the Gym at the other end. No discernible sync / timings issues over several hours of “testing”. No on the main floor where I have the inverse layout: Russound zone, Play 1, Russound zone.
Next steps: Myros control (but I wonder how this works with the other Sonos zones in party / group mode?).
