Sonos Plug-in Features not working completely on new UI6
I just upgraded to the new UI6 and wanted to report the following:
  1. In the new UI6 screen the sonos all the controls are working
  2. In the advanced tab which get to the original previous UI5 like screen:
    A. The main device screed all the controls work
    B. The “Control Tab” appears to work fine
    C. The “Player Tab” is not working and non responsive to any of the controls including album art does not show up and things like text to speech are not working.
I realize this is a new release but just wanted to let the developer know that will look forward to any comments as to updating the files to be compatible with UI6 and continue to enjoy this great app!
This isn’t even a new release. It’s an unrelease at this point. MCV/Vera may very well tweak pieces before actually releasing it so I’m not sure it makes much sense for devs to spend time on workarounds just yet.
[quote=“dinochronos, post:1, topic:179148”]I just upgraded to the new UI6 and wanted to report the following:
I realize this is a new release but just wanted to let the developer know that will look forward to any comments as to updating the files to be compatible with UI6 and continue to enjoy this great app![/quote]
So the Player tab is displayed correctly but commands are not working ?
You can check the logs to see if there is an exchange between the Javascript UI and the lua code, that means if an action is really called and handled by the lua code.
Before trying the Sonos plugin, the first thing to know is whether or not the UPnP event proxy is still working well with UI6.
