SONOS Bridge
I was doing pretty well when i had just one PLAY:5 through a bridge at my office.
it’s IP is 192.168.15.138 … I added a Play:1 and the SONOS plug in can se it… but do i need to set the Plug in to loin to the Bridge now ?
or and another SONOS device in UI5 for the Play:1 ?
TTS works if i loin tot the play:5 … takes the play:5 out of the group and TTS runs.
Is everyone ruing multiple SONOS devices for each Zone ?
No need to create a device for the bridge.
You can create a new device for your Play:1 if you plan to control it (separately from your Play:5) from the Vera.
