Sonos and upgrading from UI5 to UI7 on Veralite
About a month back I upgraded from UI5 to UI7 and all is well so far. My question however is that I had setup one of my Sonos Play 5’s to work with my Veralite when it was on UI5. I beleive when I did this there was no plugin to install the easy way and I had to do some hacking to get it work? This is by memory but all I know is that when I go to Apps/My Apps on my Veralite on UI7 I don’t see the Sonos plugin.
I think things don’t quite work the same as they would if I had install the plugin from the App store. Can someone please advise about this if you have any experience? Thanks so much!
