Somfy Venetian (lift and tilt) with Vera Edge - RESOLVED
So after some issues my “test” Somfy Venetian blind is back and working as expected from Somfy controller. Up / down / stop all working well which lets me open the blind each day to my preferred position and then close it.
I’m using the RFXtrx app to control it but it does not appear to work as well as my other somfy blind (I also have a roller blind that I bought to also test).
I followed the instructions on the vesternet website to get Vera talking to the Somfy, but I see once the device is set up there are settings for Change Angle (Venetian US / EU) which are available in the command box (so far I’ve only used “run” in the command box to pair). Do I need to do something here to make the up / down / stop more reliable ?. They do work some times but often pressing one just moves the blind a single step.
For anyone that was interested I’ve now resolved this issue. It was just a case of changing the RFY variable to VENETIAN_US (it was previously set to standard which works fine for roller blinds but not for venetian). That has resolved the issues and all working well with control via Imperihome (which before the change would give different results to the switches on the vera UI which I also found weird.
