I have a Vera that I’m, after many months, still getting started with. I have a handful of Home Manageables modules that came as part of a Vera starter kit.
I have found it very touchy and frustrating to get these to associate with the Vera. For a couple of modules I had to exclude and re-include them a couple of times to get them to associate and operate properly. Now I have one that operates fine and one that operates okay (appliance on/off) but in the Vera U/I consistently generates a “Transmit failed with code: 1” message after every operation.
What does this mean? Is there anything I can do to fix it?
I’ve grovelled through the logs and can make no sense of what I see. Here is what looks like error messages in the log:
06 12/13/11 19:08:42.121 Device_Variable::m_szValue_set device: 18 service: urn:micasaverde-com:serviceId:HaDevice1 variable: CommFailure was: 0 now: 1 #hooks: 0 upnp: 0 v:0x797b08/NONE duplicate:0 <0x803>
06 12/13/11 19:08:42.122 Device_Variable::m_szValue_set device: 1 service: urn:micasaverde-com:serviceId:ZWaveNetwork1 variable: LastError was: Node 9 failed now: Node 9 failed #hooks: 0 upnp: 0 v:0x7c33d0/NONE duplicate:1 <0x803>
02 12/13/11 19:08:42.123 ZWJob_SendData::ReceivedFrame job job#6 :OFF node 9 (0x74d698) N:9 P:35 S:5 to node 9 command 32/1 failed m_cTxStatus 1 retries 0 <0x803>
02 12/13/11 19:08:42.128 UPDATE MANUAL ROUTE2 9=(nil) <0xc04>
02 12/13/11 19:08:42.128 ZW_Send_Data node 9 NO ROUTE (nil) <0xc04>
02 12/13/11 19:08:42.281 ZWJob_SendData::ReceivedFrame job job#6 :OFF node 9 (0x74d698) N:9 P:70 S:5 to node 9 command 32/1 failed m_cTxStatus 1 retries 1 <0x803>
02 12/13/11 19:08:42.286 UPDATE MANUAL ROUTE2 9=(nil) <0xc04>
02 12/13/11 19:08:42.287 ZW_Send_Data node 9 NO ROUTE (nil) <0xc04>
02 12/13/11 19:08:42.461 ZWJob_SendData::ReceivedFrame job job#6 :OFF node 9 (0x74d698) N:9 P:70 S:5 to node 9 command 32/1 failed m_cTxStatus 1 retries 2 <0x803>
02 12/13/11 19:08:42.466 UPDATE MANUAL ROUTE2 9=(nil) <0xc04>
02 12/13/11 19:08:42.467 ZW_Send_Data node 9 NO ROUTE (nil) <0xc04>
02 12/13/11 19:08:42.661 ZWJob_SendData::ReceivedFrame job job#6 :OFF node 9 (0x74d698) N:9 P:70 S:5 to node 9 command 32/1 failed m_cTxStatus 1 retries 3 <0x803>
02 12/13/11 19:08:42.666 UPDATE MANUAL ROUTE2 9=(nil) <0xc04>
02 12/13/11 19:08:42.667 ZW_Send_Data node 9 NO ROUTE (nil) <0xc04>
02 12/13/11 19:08:42.781 ZWJob_SendData::ReceivedFrame job job#6 :OFF node 9 (0x74d698) N:9 P:70 S:5 to node 9 command 32/1 failed m_cTxStatus 1 retries 4 <0x803>
02 12/13/11 19:08:42.786 UPDATE MANUAL ROUTE2 9=(nil) <0xc04>
02 12/13/11 19:08:42.787 ZW_Send_Data node 9 NO ROUTE (nil) <0xc04>
02 12/13/11 19:08:42.941 ZWJob_SendData::ReceivedFrame job job#6 :OFF node 9 (0x74d698) N:9 P:70 S:5 to node 9 command 32/1 failed m_cTxStatus 1 retries 5 <0x803>
01 12/13/11 19:08:42.943 ZWJob_SendData::JobFailed job#6 :OFF node 9 (0x74d698) N:9 P:70 S:5 Priority 70 <0x803>
