I have a Philio 2x switch PAN04 running with Vera Lite
My wall switch should be operating as usual. So if the light is already on it should switch it of.
However right now there are situations where it does nothing until I use the wall switch again. It should change the state of the light no matter which state the walls witch has. 1. How can I change this behaviour?
When I include the Philio to Vera I get several “objects” (2xload, 2xswitch, 2xboth) However I can switch on and off with all of them. What I wanted to have is only an information wheter a switch is pressed or not. 2. How can I achieve that or use that to trigger for other devices?
3. On some switches I have removed Load1, how can I get it back?
Also what I don’t get is how I can switch on a light for only 30 seconds. 4. How can I do this?
5. How can I switch on a light for 20 seconds, after this switch on another light for 20 seconds?
I upgraded to the latest beta in hope to get the smoke and water sensor from Fibaro to work but still no luck.
WTF I’m disappointetd and frustrated…
6. Additionally is there any useful guide how to get started?
7. Where can I put in LUUP (LUA?) code. (right now I think this is the easiest way to do everything - the UI is just useless, right?
8. Can I use LUUP to do this: IF temperature is over X AND it is daytime AND Scene X is on AND Motion sensor is tripped DO this and this and this for ten seconds?
[quote=“dawiinci, post:1, topic:179181”]I have a Philio 2x switch PAN04 running with Vera Lite
However right now there are situations where it does nothing until I use the wall switch again. It should change the state of the light no matter which state the walls witch has. 1. How can I change this behaviour?[/quote]
I’ve never heard ofthis switch, but your description sounds like it is a wiring problem. Does teh switch behave normally without Vera? If not, it’s probably a wiring problem.
When I include the Philio to Vera I get several "objects" (2xload, 2xswitch, 2xboth) However I can switch on and off with all of them. What I wanted to have is only an information wheter a switch is pressed or not.
[b]2. [/b]How can I achieve that or use that to trigger for other devices?
I'm not sure I understand this question. Scenes are "action scripts" that can be activated by triggers. I think you are asking for a [url=http://support.micasaverde.com/customer/portal/articles/730948--vera3-creating-scenes]scene[/url] with a [url=http://support.micasaverde.com/customer/portal/articles/730949]trigger[/url] to run the scene.
[b]3.[/b] On some switches I have removed Load1, how can I get it back?
Exclude the device and then include it again.
Also what I don't get is how I can switch on a light for only 30 seconds.
[b]4. [/b]How can I do this?
Use a scene to turn on the light and then use a delayed action to turn it off. [url=https://mios.desk.com/customer/portal/attachments/70915]Click the scene's "Immediate" dropdown[/url] click "Manage Delays" and then add the delay and the delayed action.
[b]5. [/b]How can I switch on a light for 20 seconds, after this switch on another light for 20 seconds?
Again, use a scene with a delayed action.
WTF I'm disappointetd and frustrated...
Can't help you after this. I have no experience at all with the beta.
I tried to answer this the last time you asked it two days ago, but by the time I pressed Submit your post was gone.
I reckon you’re using toggle switches instead of momentary switches. Not all of the in-wall devices play well with toggles, and if they are expecting a momentary switch then yes, you sometimes will have to operate the switch twice: once to return the switch back to open, then once to re-close the contacts.
Some devices have a software configuration option where you can tell it to expect a toggle switch on the input, whereupon the device will consider both closing and opening the contacts as operating the switch. It doesn’t look like the PAN04 has this option from the PDF of the manual that I found online.
Edit: looks like it can accept toggle switches, from that product page you posted in your other thread. You will need to find out which Z-Wave parameter you need to set, and what value to set it to.
I suggest you familiarize yourself with PLEG (couple of plugins) which make your life much easier or dive into the LUUP programming and they have a full subforum here for that and a great starting thread pinned at the top. Here is the direct link for your reference.
