[quote=“silvereagle2208, post:4, topic:172157”]@Bernfrin
This should not be a problem for you. I have a setup similar to yours: Vera3, running firmware 1.5.408. I have at least seven VRS15-1LZ switches installed and they are rock steady. It looks like you will need to do some experimentation to solve your problem.
I assume you are using UI5, since the Vera3 uses UI5 by default.
Have you tried adding the lights controlled by VRS15-1LZ switches to the scenes where you activate lights controlled by the VRP03-1LW modules? Does this work or does the addition of a VRS15 switch “poison” the scene? If this does work, you could create a new scene and have this new scene control your VRP03 modules. If this works, you then add your VRS15 switches to the new scene. If this works, remove the VRP03 switches from this scene. If it still works, you have a working scene that controls your VRS15 switches and you can delete your original scenes that did not work.
What type of icons are you seeing with lights controlled by the VRS15 switches On my UI5 system, the icon is a CFL bulb. If you have an incandescent bulb icon, something is not correct with the devices that controls your VRS15 switches.
What is the distance from the VRS15 switches from the Vera unit? If you have a large distance from your Vera3 to the VRS15 switches and your mesh network is not configured properly, you will have difficulties. Do you have or can you obtain a copy of the ADD program written by Ap15e? That program will show you your systems Z-Wave routing index. I believe that since Ap15e left the forum, the ADD program is no longer directly available from the forum. However, I imagine one of the senior members of this forum can help you obtain a copy of the ADD program or an equivalent that will show you the status of you Z-wave mesh network.[/quote]
I am using U15.
I did move the VRS15-1LZ switches to scenes set up for my VRP03-1LW switches. The VRS15 modules didn’t “poison” the scene, but they also still did not work. I.E. they still did not respond at all.
The icons that I see with the VRS15s is a CFL bulb.
Distance from the Vera3 unit to the modules is approximately 30 feet to the side entrance and 40 feet to the front entrance.
I truly appreciate your help. Since I have been “struggling” with this issue for about a week now and have not been able to resolve the problem I have decided to disconnect the Vera3 and restore my HS system. I just set up identical scenes in HS. When I ran the scenes for the VRS15s, they responded immediately. Not sure why Vera3 doesn’t.
Regards
Ron Bernier
