SOLVED - TTS - SAY says nothing ...
Plugin works; Plays music nicely :slight_smile: … tested Say : While playing the music, it fades music to 0 but then just silence for 5 seconds, then music is back on.
Any ideas ?
/Martin
Maybe I should mention that NO mp3 files are created in /www
And yes - I have put the silence.mp3 in /etc/cmh-ludl :wink:
/Martin
In the Advanced tab - should RouterIP and RouterPort be of my LAN - or Sonos Bridge ?
/Martin
I had these exact same symptoms and just today I reloaded the xml, js, and lua files and it seems to be working now.
Edit: the only difference from the first time I loaded them is that this time I checked the “Restart Luup after upload” for both batches of files. The instructions for the plugin say to just do that for the second batch.
Hmm…added a new device and deleted the old one; Seems to work :slight_smile:
Please add “solved” in the title of the subject.
In the initial screenshot, I see two interesting things:
  • the presentation is not as expected. Are you using Safari ? If you are, could try my new “working in progress” version here: trunk – Sonos Wireless HiFi Music Systems and tell me if it is better ?
  • I see that you have “ZoneBridge”. I would like to filter the bridge from the listed zones. Could you filter ZoneGroupState in the logs. When ssh connected to your Vera, run this command:
tail -f /var/log/cmh/LuaUPnP.log | grep ZoneGroupState
Then reload the Vera and provide the result.
Done
No - sorry
- I see that you have "ZoneBridge". I would like to filter the bridge from the listed zones. Could you filter ZoneGroupState in the logs. When ssh connected to your Vera, run this command: [code]tail -f /var/log/cmh/LuaUPnP.log | grep ZoneGroupState[/code] Then reload the Vera and provide the result.
I’ll be back.
/Martin
Done[/quote]
Thank you.
No - sorry
Which one so ?
On my side, I have a normal display with IE, Firefox and Chrome.
I’m using Chrome on Mac.
/Martin
Come to think of it I think that the screenshot was from Chrome on PC (which I also have)
/Martin
[quote=“flyveleder, post:9, topic:178882”]I’m using Chrome on Mac.
/Martin[/quote]
Please let me know if the version in trunk provides a better result (Play and Say buttuons at right and no scrollbar.
If still not ok, I could guide you to which value to adjust in the js file.
08 01/16/14 15:04:40.488 JobHandler_LuaUPnP::HandleActionRequest argument ZoneGroupState= <0x30c2d680>
[quote=“lolodomo, post:11, topic:178882”][quote=“flyveleder, post:9, topic:178882”]I’m using Chrome on Mac.
/Martin[/quote]
If still not ok, I could guide you to which value to adjust in the js file.[/quote]
I hadn’t even noticed; sometimes it’s ok - sometimes not.
I have just installed the trunk version - I’ll report if the problem comes back at some point.
Brgds,
Martin
Thank you.
I see the interesting tags “IsZoneBridge” and “Invisible” all set to “1”.
I will provide a fix to not take care about bridge.
It’s also shown in the “GROUP”-tab.
/Martin
[quote=“flyveleder, post:15, topic:178882”]It’s also shown in the “GROUP”-tab.
/Martin[/quote]
Yes, it is one of things I have to change.
  • a ALL command (Say for example) shoulkd not consider the bridge.
I would be interested to know if it stops working again…
I had the same problem and had to keep reloading the files a few times as it would periodically stop working - it’s ok now, but I’m curious if yours plays up again.
I’ll change the title again to “UNSOLVED” if that happens :wink:
/Martin
@flyveleder : could you try the new version in trunk please ?
Now, your bridge unit should not appear, neither as audio input in the Player tab, nor in the Group tab, nor in the Help tab.
[quote=“lolodomo, post:19, topic:178882”]@flyveleder : could you try the new version in trunk please ?
Now, your bridge unit should not appear, neither as audio input in the Player tab, nor in the Group tab, nor in the Help tab.[/quote]
Seems to work; thanks.
