SOLVED - TTS getting cut off
When I use the say command on my Play 1, the sound is getting cut off after about 5 seconds. I’m guessing that the plugin is starting playback before the mp3 had finished downloading but that’s just speculation.
If I type a long sentence in the Say box and keep hitting say, it tends to get to about the same point in the sentence plus or minus a word. That’s what made me think it’s a timing issue with the download.
Any ideas?
Nevermind :-[
I had downloaded the Sonos_silence.mp3 file using wget and I apparently had downloaded the trac page for it instead of the actual file so my total mp3 length wasn’t long enough so the duration being calculated around line 1326 of I_Sonos1.xml was off.
My bad.
Ok, fine.
Please edit the title of the subject, adding “Solved” in the title.
