Hi everyone,
Really hoping someone has seen this problem before and can help. I have a Vera3 running firmware 1.7.541 and I installed the Sonos plugin per the instructions here:
http://code.mios.com/trac/mios_sonos-wireless-music-systems
Installation was successful with no errors, UPnP discovery worked great and found all of my Sonos devices quickly. I am able to see what is in queue, play, pause, stop, change volume with no issues.
The problem I am running into is when I try to run a scene. I created a manually activated scene to alert with a URI located on my NAS box (no user restrictions). However, when I activate the scene, Sonos just changes to the next track or mutes for the alert duration I have configured. The URI I am using is: //192.168.77.1/routernas/chimes/doorbell.mp3, which loads up fine from within Sonos and plays, but not through my scene. I can even go into the Vera device, select Player, set URI to x-file-cfs, enter the same URI, hit Play, and it plays fine. It just won’t play this URI through a scene that I’ve created.
I’ve tried everything from a) setting the URI first, then creating a second action to play it, b) trying to just play an alert with all of the URI info, c) trying it on different Sonos devices, d) trying it with music already playing and without music playing, d) resetting my Vera3 and reinstalling the app, e) rebooting my Vera and Sonos Connect:Amps, and f) leaving the URI blank in the alert function, which actually plays something called say.7.mp3 and says, “The monkey is on the branch, the mouse is under the table.” I even tried using the Luup code instead of the advanced editor, but every time I do it this way, it actually deletes the Sonos device that I have specified.
Does anyone have any suggestions?
