(SOLVED) cannot disable X10
I finally replaced my last X10 device, so I am X10 free now ! Just tried to disable the protocol in the Rfx device (firmware v69, plugin beta 2) but I cannot disable it. I click on disable in the RFXtrx settings, and I get an error ‘no implementation’. I have tried changing it in the advanced section by entering 0 for x10 but when I save and go back in, it is still enabled and the 0 in advanced is replaced by 1…
Use RFXmngr to disable the X10 protocol, Click Set Mode and Save Settings.
Good idea, never thought about that one. Just a pain to get to it and take it to the PC for me.
The plugin is certainly not correctly installed if you got a no implemenion error.
Are you at least running UI5 ?
yep UI5 1.5.622
Strange if it isn’t installed properly, everything seems to be working fine (and has been for a long time). My Oregon sensors, including the energy ones, Lightwave RF, and x10 was working fine too. Do I need to uninstall and then reinstall ? I will do it if I have to but a lot of hassle as I have a lot of devices
Just upload the files and reload. Keep your devices.
Uploaded the files again, i kept all my devices, and could disable x10 protocol without any problems.
