Hi All, I?m asking for help, again. Can?t figure out TTS to my Sonos (Portable) and the ?access denied? issue. I?ve attached screenshots to show what I?ve done so any errors might be visible.
Per the checklist, item 2, I first want to verify that I DO have access unsecured. On UI7 the tab ?User & Account Info / Unit Settings / Secure Vera? shows a kind of greyed out check box, but the box has a faint greyed out check mark in it.
If I click the box, it gives me the warning message: ?By enabling this option you will not have local access to your Vera. You will only be able to access your Vera through relay. Are you sure you want to continue?? I cancel out of that, so I assume (?) that proves it is unsecured, and the faint check mark is just another Vera-ism. Does that sound right? If this is the problem, can I unsecure it myself, or do I still need Vera Tech Support to do it?
On item 3 Vera shows ?Internet access is ok?
Second question is on item 4. Same subnet. I can?t find the subnet on the Sonos. It?s 255.255.255.0 on most devices on my network, but I can?t find anywhere that shows it for the Sonos. Any suggestions on this?
I?ve tested a simple scene with both Lua code and adding steps in the advanced editor. They both work with ?PlayURI?, but with ?Say? the scene claims ?success? but I hear no output.
The TTS option in the Sonos plugin is where I see the ?access denied? message.
I have not yet tried steps 8 and 9 because it?s a bit complicated, and I?m not real comfortable uploading stuff into Vera. If that is still necessary, I will give it a shot, I just wanted to make sure that was still required. Is that my next step?
Thanks for any help anyone can provide.
