Locally, over WiFi. I do this to “test” the status of various Alarm behaviours where I often have to be away from the computer (to activate the Alarm, Leave the house etc)
Yes, the embedded IFRAME in the HTML of the Findvera.com version is a PITA. There are ways (after login) to get just the “Control” component to come up full frame, using a Desktop browser, but I don’t think that’s possible with the iPhone.
Take a crack at the L_sPhoneUI.lua, it’s downloadable via the Vera URL:
http://192.168.x.x/cgi-bin/cmh/view_upnp_file.sh?file=L_sPhoneUI.lua.lzo
Sub in your Vera’s IP, and then do a View-Source on what comes down.
It’s basically this part that needs tweaking:
[code]function lug_sPhoneRequest_sensor(lul_device,lul_description)
local lul_Armed = luup.variable_get(“urn:micasaverde-com:serviceId:SecuritySensor1”,“Armed”,lul_device)
if( lul_Armed~="1") then
status_arm=''
status_bypass='_h'
else
status_arm='_h'
status_bypass=''
return '<img src="/cmh/iphone_file/icons/security.gif" alt="" width="44" height="43" align="absmiddle" class="icon" />' .. lul_description .. '<br>\n' ..
'<a href="data_request?id=lu_variableset&DeviceNum=' .. tostring(lul_device) .. '&serviceId=urn:micasaverde-com:serviceId:SecuritySensor1&Variable=Armed&Value=1&time=' .. tostring(os.clock()) .. '"><img src="/cmh/iphone_file/buttons/arm' .. status_arm .. '.gif" alt="" border="0"/></a> ' ..
'<a href="data_request?id=lr_sPhone_action&room=' .. luup.devices[tonumber(lul_device)].room_num .. '&device=' .. tostring(lul_device) .. '&service=urn:micasaverde-com:serviceId:HomeAutomationGateway1&action=SetVariable&DeviceNum=' .. tostring(lul_device) .. '&Service=urn:micasaverde-com:serviceId:SecuritySensor1&Variable=Armed&Value=0&time=' .. tostring(os.clock()) .. '"><img src="/cmh/iphone_file/buttons/bypass' .. status_bypass .. '.gif" alt="" border="0"/></a> '
[/code]
with a few more calls to [tt]luup.variable_get()[/tt] to get the value of “[tt]Tripped[/tt]”, and then a snippet of HTML to display the status.
I was using relative URL’s like:
[tt] /cmh/images/red_circle.gif[/tt] AND;
[tt] /cmh/images/green_circle.gif[/tt]
for the circles, as these resolve correctly on the FindVera.com service as well as locally.
