Smart Virtual Thermostat and Horstmann ASR-ZW receiver problem?
Hello,
I’m using the Smart Virtual Thermostat plugin with the Horstmann receiver and I noticed an strange behavior.
While the thermostat is always on until it reaches the set point temperature, the Horstmann receiver is constantly stopping along the way. It stops for a minute and then resumes.
I don’t know who is to blame for this, or if this is a wanted behavior.
Here are the graphs. The first one if from the Virtual thermostat and the blu vertical lines are the stops it makes.
It seems to stop once every hour, corresponding with the calculation period set in the variable.
I think there’s no need to make this stops if the result of calculation is you need to keep going.
Is there an easy fix for this?
Thanks in advance.
