When I do anything it would take 15 to 20 second for something to happen. Also,tstat shows setting at 68 setpoint but vera reads 78 which is correct or tstat. The current temp appears to be correct.
Just realized that status report is incorrect as well. I would turn on a light and when it does turn on, status shows still being off. Did multiple refresh but no change
I had this problem with my Tstat. It was the closest device to my Vera compared to all of my other devices and still had trouble reading and communicating with it. I moved my Vera slightly and the problem went away.
Wireless can be tricky.
Seems to be an imperihome issue cause authomeationhd triggers instantly. Everything I’m doing with imperihome is lagging all of a sudden. True on both of my devices.
I have a similar issue, one of my tstat always seems to display the incorrect setpoint on Imperihome even though it is set correctly and displays properly in UI7 GUI and AuthomationHD. I only use Imperihome on my tablets and I haven’t had time to investigate.
