Slow response - should I "heal", "repair", or "restore", and how?
Last weekend I installed six new GE dimmers and switches, for a total of 14 devices in my VeraLite based system. When I still had only 8 devices, switching scenes was nearly instantaneous, half a second at most. But now some devices take up to seven seconds to switch.
TL;DR version –
Where is the Repair/Restore/Heal option in the current interface? Or is a seven second delay normal and there is nothing I can do?
Detailed account –
I consulted the user guide, knowledge base and wiki. All of these sources mention a procedure that will rejigger the mesh network, but give it three different names: “repair”, “restore” and “heal”. And I can find none of them in the current user interface.
“Repair” is mentioned here:
http://support.getvera.com/customer/en/portal/articles/716646--vl-z-wave-troubleshooting
…but screenshots show a blue interface and a “Repair” tab under “Z-Wave Settings”, but my interface is green and there is no “Repair” tab. Presumably this describes a different version of the software than what I have.
“Restore” is mentioned here:
http://support.getvera.com/customer/en/portal/articles/1630803-settings-tab
It seems to describe the same thing, and the button it shows exists in the current interface, but clicking it prompts me to select a backup. Apparently I misunderstand what that paragraph describes - I wasn’t looking to restore from a backup but get the system to optimize the Z-Wave mesh routing.
“Heal” is mentioned here:
http://wiki.micasaverde.com/index.php/Heal_Network
…but I cannot find the “More Z-Wave Options” it mentions, or anything like it. Presumably this is for an older version of the front end software.
So - I’m confused. Where is the Repair/Restore/Heal option in the current interface? Or am I barking up the wrong tree, there is nothing to fix or optimize, and the seven second delay is perfectly normal?
-Ron.
Me too is experience very slow respond. Both power switches and siren is lagging big time. One of my scenes turns on 5 power switches and it takes between 15-30 sec. Not OK!
/J
Excellent question about scaling up a zWave network!
I can see why polling all nodes and discovering device routes grows exponentially longer…
but activating node-XYZ is about sending zWave commands down known device routes.
Sent from my GT-P3110 using Tapatalk
I think fourteen devices is still very modest. I’m only just getting started.
All six new devices are AC powered, so I think they will act as repeaters. Should make the network more robust and/or faster, no?
-Ron.
All of a sudden my Vera Scenes are being delayed too. I have a light switch turn on three lamp modules and just this week this scene is being delayed by 30-120 seconds…
To answer your original question if you are using UI7 there is no longer a heal/repair option. If your interface is green it sounds like you’re on UI7.
Since installing my new UI7 VeraEdge versions (01.07.1320, 01.07.1419), I observe very important latencies (3-5 seconds) the sensor response Everspring SM103 (Wireless Door / Window Detector) .
Previously, the responses of these sensors were immediate.
This is very detrimental in my applications.
Does anyone has a solution?
