Does anyone had advice for using scenes to control an Evolve LRM-AS with a Leviton VRCS4-M0Z scene keypad?
The scene simply turns on one light and works if started from the Vera UI and mobile apps. But when associated with the Leviton scene keypad the LED goes green for a second, then off. Below are detailed logs when trying.
Log when started from the Vera:
JobHandler_LuaUPnP::HandleActionRequest device: 0 service: urn:micasaverde-com:serviceId:HomeAutomationGateway1 action: RunScene <0x2d5c3680>
JobHandler_LuaUPnP::HandleActionRequest argument SceneNum=1 <0x2d5c3680>
Scene::RunScene running 1 Outside On <0x2d5c3680>
sbrk JobHandler_LuaUPnP::HandleActionRequest from IP:255.255.255.255 pMem 0xbae000/12247040 diff: 2355200 <0x2d5c3680>
JobHandler_LuaUPnP::HandleActionRequest device: 22 service: urn:upnp-org:serviceId:Dimming1 action: SetLoadLevelTarget <0x2d5c3680>
JobHandler_LuaUPnP::HandleActionRequest argument newLoadlevelTarget=70 <0x2d5c3680>
Device_Variable::m_szValue_set device: 22 service: urn:upnp-org:serviceId:Dimming1 variable: LoadLevelTarget was: 0 now: 70 #hooks: 0 upnp: 0 v:0xa66690/NONE duplicate:0 <0x2d5c3680>
But when triggered by the Leviton VRCS4-M0Z Vizia RF + 4
Event::Evaluate 1 T Outside on scene Outside on is true users:(null) allow:1 <0x2b3a3680>
Scene::RunScene running 1 Outside on <0x2b3a3680>
sbrk JobHandler_LuaUPnP::HandleActionRequest from IP:255.255.255.255 pMem 0x8de000/9297920 diff: 2101248 <0x2b3a3680>
JobHandler_LuaUPnP::HandleActionRequest device: 22 service: urn:upnp-org:serviceId:Dimming1 action: SetLoadLevelTarget <0x2b3a3680>
JobHandler_LuaUPnP::HandleActionRequest argument newLoadlevelTarget=100 <0x2b3a3680>
ZWaveNode::ReceivedMessage node 34 device 22 skipping SetLoadLevelTarget because it’s a scene controller <0x2b3a3680>
ZWaveJobHandler::DoReceivedFrame m_iFrameID 135 done 1 <0x2bea7680>
The scene setup works when controlling Jasco relays, just not the Evolve dimmers.
Any advice? Thanks
