Siren that makes milder sounds
I am looking to add a siren to my system. I was also hoping that I could make it emit chirps or something milder than a siren blast. I am not familiar with zwave sirens. Can you control the duration and/or volume? I am looking to emit a friendly reminder to family members in some situations. Say beeping every 5 seconds if a door is left open that shouldn’t be. I also need the full on siren capability.
None that I know of… You could take one apart and modify it to tone it down
Or, and expensive solution but more flexible is use voice annunciation using the sonos plug in :slight_smile:
A play:1 is $200.
I’ve seen some z-wave sirens that had the ventilation/sound holes covered with duct tape and made more bearable sound that could be heard from 2-3 rooms away but lacked the normal power that wakes all the neighbors. You might try that with your existing siren, if you have one. I will try to find out the make and model of those, they were white and disc-shaped, about 2 inches / 5 cm thick.
The “duct tape” trick is what I use for all the children toys that makes sound. Works extremely well in most cases.
I’m not sure if you have an alarm system, but I do what you are trying to do by having vera change my alarm’s CHIME status. When I do that, the panels chime. So, if a door is left open for some period, you could trigger the sound.
Well… now that’s clever! :wink:
I taped/put foam in the Fortezz Siren which got about a 30% reduction.
While it doesn’t help with the visual strobe, I ended up putting it in the closet until it was well tested (as I am using Vera as my alarm system).
I’m not sure if you have an alarm system, but I do what you are trying to do by having vera change my alarm’s CHIME status. When I do that, the panels chime. So, if a door is left open for some period, you could trigger the sound.[/quote]
Emulating an alarm is actually what I was trying to do. I think I am just going to install a DSC alarm and integrate it with Vera. I was going to try and use the Vera on its own for a ad-hoc alarm. One reason I wanted the chirping was to indicate the mode need to be changed from away to home when you entered the house.
How about setting up your doorbell to ring a few times to remind you?
I wish there was a way to modify the Everspring Z-Wave siren to only activate the strobe vs the siren and the strobe. It only gives you the option to change the decibel setting from 100 down to 90. Even though it’s not possible to externally modify the device to do that I would honestly be willing to buy one and just snip a wire inside (if it was that easy?) to disable the siren/audiable aspect and just leave the strobe so I’d have a visual indication only that a sensor/scene was tripped. Has anyone tried modifying any of these sirens in this drastic way so that only the strobe function would work??
there are several examples in the Forum of blinking a light in a scene, Lua or with PLEG if you want to go that route.
http://forum.micasaverde.com/index.php/topic,3015.0.html
or
http://forum.micasaverde.com/index.php/topic,18240.msg141168.html#msg141168
Any flasher would work connected to something like a MimoLite or similar wave relay
I bet it can be… So much I feel like ordering one to find out :slight_smile:
If your using an alarm panel you can buy a strobe only for it. And on that note,
You can make what you want with a zwave switch or receptacle and a 12v power supply and a alarm strobe.
The Fortrezz ZWave Strobe/Alerm has a strobe only (dimmed 1-29%), Siren only (30-59%), or Stobe and Siren (dimmed 70%+) options
Yep; disconnected the siren part in the Fortrezz.
@AgileHumor: I am aware that the Fortrezz Strobe/Siren had that strobe-only feature but that particular siren must be powered by AC voltage, correct? The battery inside is only for backup from what I understand? I like my Everspring model (actually got the generic version that goes with the Lowes Blue Iris system) because it is battery powered and makes it easy to put anywhere.
@oTi - How easy was it to disable the siren in the Fortrezz? Was it as simple as disabling a wire or a connection??
