I have experimented with this and it appears that if you have two different triggers for the scene, both must be true before the scene will execute. Is this correct or did I do something else wrong?
thanks
Bill
thanks
Bill
You must have a different problem.
Triggers are logically ORed together so any trigger or schedule will run the scene.
thanks!! I think I figured it out.
You are right. My Thermostat has a mode to cycle the fan, regardless of whether its heating or cooling. the triggers I was using was AC actively cooling or Fan running. I think the Fan running is not working right, I was trying to turn my ceiling fans on if either the A/C was running or the Fan.
Thanks again,now I know exactly how it treats multiple triggers
Bill
I always found the diagram here very helpful…
http://wiki.micasaverde.com/index.php/Luup_Scenes_Events#Adding_Lua_code_to_scenes_and_events
