I just purchased two Aeon Labs sensors for my two arage doors. What I would like is a simple notification sent to me after 9:00PM if either of the doors is open.
Can someone walk me through a step by step as to how to accomplish this please? I am a newbie so simple tutorial would be greatly appreciated!
An Advanced scene is one that needs logic more than just the Logic OR of it’s input triggers. Your request requires the Logical And
You have two options:
[ol][li]Use Luup Code - Trigger on Door Tripped, but cancel the trigger in LUUP if not in specified time interval. Search the Forums you will find examples of this.
Also trigger on a schedule at 9:00PM every day, cancel if door is not open.[/li]
[li]Use Program Logic Event Generator plugin.
Inputs:
DoorOpen - When GarageDoor sensor indicates Open
Conditions:
DoorAlert - DoorOpen and (21:00:00;NOW);
Notification:
Condition DoorAlert has been satisfied
[/li][/ol]
I guess I will opt for suggestion #2 as I have no idea what to do with your first suggestion, still in baby step mode!
Let me know how you make out with this. I am looking to do the same thing except I want an indication at 11PM if any of my doors are not locked (garage door included).
Here is what I did for my garage door, I set a scene to arm my garage door sensor at 9pm and then a delay of 5 seconds and disarm. then have another scene and set up a trigger that will send me a notification if the device is armed and tripped.
The second scene would send the notification right away within that 5 seconds when the sensor is armed and tripped. If its armed and not tripped nothing happens.
I would like to try your scene setup as I am having issues with Richard’s suggestion. It doesn’t seem to work now, not sure why
Can you provide me with a step by step to create the two scenes you suggested please or maybe a screen capture? I am unclear on the “delay” and the “disarm” part of the 1st scene and how to accomplish that. I see how to add a delay, but I don’t see how I then add the disarm into the first scene that is “armed”?
create one scene and click the arm button on the door sensor, click on immediate next to the scene name at the top and add a 5 second delay, then click disarm on the door sensor, then click on the scheduled tab and add a schedule for day of the week, click every day and add the time in of 21:00 (9pm) then save.
this scene will arm your door sensor for 5 seconds every night at 9pm and if the door is open when it is armed it will send a notification if you have your second scene setup with correctly. in the second scene simply click on the trigger tab, select the door sensor, select a armed sensor is tripped, name the trigger and select sensor is tripped and check the account that you want notified, then save.
If I leave the door open, right now 9:25PM, and run the first scene, shouldn’t I still get the text message? I don’t…
I have two triggers listed, one for each garage door. Is that the problem, both doors need to be triggered? EDIT: tried to open both doors, that’s not the problem
If I arm either garage door manually, then open either door, I do get the text message.
[quote=“fmzip, post:1, topic:174397”]I just purchased two Aeon Labs sensors for my two arage doors. What I would like is a simple notification sent to me after 9:00PM if either of the doors is open.
I have no idea why it is not working for you, I have it set up exactly how I described and I just tested it. I opened my garage door then manually armed then disarmed the door sensor simulating the schedule and a notification came through, maybe its because you have two triggers in one scene?
Having one trigger solved the problem. Not sure why, might be the same reason the PLEG stopped working as well??
However, the more I think about this, this isn’t fool-proof. For example, if I took the garbage out after 9:00PM, and opened garage door 1 and came back in and inadvertently pushed the button for garage door 2, garage door 2 would be left open all night…
That’s why I am thinking an hourly check from dusk to 10:30PM may be a better concept
