I have a scene that turns on the door lock every 1 minute/ Locks the door every min. I want to have another scene that I need the door to stay unlocked for 12 minutes or so when it is activated. So basically a code is pressed on the door, a light turns off and then 10 minutes later the light turns on to 50% and then the door re-locks at 12 minutes. However, like I said the door already re-locks every 1 minute so but I need it to stay unlocked for the full duration. Does anyone know of a way outside of writing luup code in order to do this? Any help would be greatly appreciated. Thank you in advance
The most practical answer is probably to use PLEG if you don’t want to use lua. You are asking for something to be conditional which isn’t possible in the native interface without a bit of lua. (Unless someone proves me wrong - I’m all ears.)
Other choices: install AltUI and use the blockly editor in it (creates the lua expression you need via a GUI) or use the AltUI workflows (like state machines).
Hello. Do you install altui as an app through vera plus or just on a computer and then copy and paste it to vera gui?
It’s available from the MiOS App Store for direct loading into Vera.
