Short notification sound or fast switch
I’m looking for the best way (a way) to create a short sound at a modest volume to notify me when someone approaches my house.
The sirens that are available for z-wave are way to loud and will probably sound too long. I could use my doorbell, an old-fashioned analog 12v ringer with e.g. a fibaro micro module and wire it parallel to the doorbell button. Unfortunately the minimum switch time for a command in the vera seems to be 5 seconds. This will be annoying. I could reduce it with hardware using one of these: Long-run timer kit but it becomes somewhat messy this way. Is there a way to switch a fibaro switch or something else for a shorter duration than 5 seconds (e.g. 0.5s)?
If there is a useful signaling device I would be glad to hear it as well. I’m missing a z-wave equivalent of this fs20 signaling device: Signaallamp “FS20 SIG” (sorry not available in english). This device reacts to different events and can play different sound files for different events, plus it gives a visible feedback. I guess there is no easy way to use an FS20 device in a z-wave network and I didn’t find a z-wave alternative. The wintop iAlarm seems to be a similar device but I can find very little information and no manual. It may just be another z-wave alarm.
It would also be OK if my phone could ring briefly with a special ringtone that is reserved just for alerts. But I only see an option for sms and I don’t want to keep deleting sms-messages.
I hope someone found a solution for a similar situation. Thanks.
Arjan
Don’t know if that help you, but my duewi switch can be switch on then off within 0,2 sec. I use it to change my light pool. To do this I use a sleep command.
Envoyé depuis mon GT-I9000 avec Tapatalk
Gilles, thanks for your answer. That would easily be short enough!
I guess the sleep command is used in the programming environment? I’ll delve into this in the weekend. I’ll see wether my fibaros can reach this speed as well. Otherwise I’ll get a duewi, I need more switches anyway.
