Can the Vera Lite be set up using a network in one house and changed when moved to another house?
it should work, assuming that devices are within range. Would be a good idea to do a network heal when settled at the new place …
Capjay,
Would the devices continue to be paired or would I have to pair them over again? Thanks.
they will continue to be paired till you either you “exclude” them or reset the z-wave network.
