Setting up Linksys WVC80N IP Camera
Has anyone been able to setup Vera2 (using Generic IP Camera Plugin) to receive video from a Linksys IP Camera (WVC80N) streaming video in MJPEG format. I can setup for snapshots but not streaming. I’ve been following the reference at the wiki below, with no success.
http://wiki.micasaverde.com/index.php/Remote_Camera_Streaming
To those folks who are interested.
After a few tries over the weekend, I was able to configure the camera to do snapshots and stream video content. Procedures at the wiki (http://wiki.micasaverde.com/index.php/Remote_Camera_Streaming) are a little confusing. Here is what I had to do to made it work:
Under Settings tab:
URL =/img/snapshot.cgi?size=2&quality=1
User = blank (you may need to include user & password if your camera is configure so, I don’t use user an password while testing)
Password = blank
IP Address = xx.xx.xx.xx (IP Camera address on my internal network)
Under Advanced tab:
DirectStreamingURL = /img/video.mjpeg (path to the location on your camera for mjpeg or MPEG files)
URL = /img/snapshot.cgi?size=2&quality=1 (this automatically is filled from the URL under the Settings)
So, now under “Camera Control” panel I see an snapshot and when I click “Streaming” option under the “Settings” tab I see streamed video from my Cam.
Enjoy!
Thank you for taking the time to figure out how to enable the Linksys WVC80N IP Camera to stream video. It greatly increases the usability of the camera.
I found a couple of quirks when doing video streaming through Vera:
When using the camera in snapshot mode, you can enable lights to provide illumination for the snapshot. However, the video streaming mode does not seem to support this feature.
Also, I am having difficulty getting video streaming to work when accessing Vera from cp.mios.com via a dashboard. Video streaming works fine when I access the camera via Vera on my local network.
I tried the light switch, and I have the same issue, light switch doesn’t go ON while streaming. But, it works very well with snapshot.
On the second issue, I have no difficultly streaming video while connected remotely via cp.mios.com. I haven’t done anything special. The only thing I missed to indicate in my instructions is that I have the attribute “embeded” (under Advance tab) checked. I don’t really think that’s your issue, but I thought I mention it here for completion.
Take a took at the following link, it references steps needed to enable streaming video remotely that may be helpful. However, I didn’t follow it.
