How do I install additional cameras?
Devices → Cameras → UpnpDevFilename: D_DigitalSecurityCamera1.xml → Add device
does not work.
does not work.
This worked for me with a Panasonic camera.
devices → luup plugins → install/uninstall → locate the plugin and select install
Then it will show under devices where you can configure it. Then I supplied IP:PORT, MAC address, Username, PW.
Go to plugins and click on install generic IP camera… or Panasonic IP camera.
They only differ that Panasonic installs custom implementation file
Thanks for the hints.
What I was going to accomplish was to add an additional camera. The plugin was already installed. There was no option to install the plugin once more (just “Uninstall”).
I somehow managed to install the additional cameras by feeding UpnpDevFilename with
“D_DigitalSecurityCamera1.xml” and/or “urn:schemas-upnp-org:device:DigitalSecurityCamera:1”. The new cameras are working, but now I have empty phantom devices on the dashboard (not in the device view), which cannot be deleted.
The Wiki documentation is lacking/outdated.
That’s strange because I do have “install another camera” link, so I just installed few when I needed. I also didn’t have any phantom devices - once the device is removed from Device view, it’s gone
I also have the option to install an additional camera option under the luup plugins. Only shows if a camera is already installed.
Screenshot attached. No option to add an additional camera.
IMHO - it’s a support ticket… or firmware update problem
Un-deletable phantom device, not visible in device view.
I’d have to agree. I added the generic camera and it instantly gave the option to add another.
