Setting the watts on a binary or dimmer device
I saw there used to be a way to set the wattage use for a specific device like a binary device or dimmer device.
It used to be in the settings location for the device.
I looked but I can’t find a way to set this up anywhere.
Was it removed??? Is there any way to set it up now?
Need to set the variable UserSuppliedWattage in the usual power serviceId.
Eg. [url=http://forum.micasaverde.com/index.php/topic,30310.msg233600.html#msg233600]http://forum.micasaverde.com/index.php/topic,30310.msg233600.html#msg233600[/url]
Great… Thank you so much. I added the variable in UI7 via Device → Advanced → New Service.
I am not too clear on what on what the difference is between the “New service” and “New variable” fields. Should these be the same values?
No, definitely different things.
New service = urn:micasaverde-com:serviceId:EnergyMetering1
New variable = UserSuppliedWattage
Can I remove a variable I have created??
Not very easily at all. I suggest you leave it, it should do no harm.
I found the post the describes how to remove the variable I put in there. I am going to just leave it though. I don’t see any reason to mess with it.
One last question in regards to the new variable “UserSuppliedWattage”.
I noticed on the documentation ([url=http://wiki.micasaverde.com/index.php/Luup_UPnP_Variables_and_Actions]http://wiki.micasaverde.com/index.php/Luup_UPnP_Variables_and_Actions[/url]) that it says to enter the data different for a thermostat.
“Note: For thermostats, UserSuppliedWattage consists of 3 numbers separated by commas. The default is 1500,1500,300. The first number is how many watts are used when the thermostat is in ‘heat’ mode; the second is how many watts are used when the thermostat is in ‘cool’ mode; and the third number is for the ‘fan only’ mode.”
Is this still correct? Wiki seems a little out of date…
Yes, I think that’s still correct (you’re right, much of the Wiki is out of data, but it’s the best we have!)
I’m not a thermostat user, so can’t check myself.
