SetFileToPlay no longer works on UI7 ?
Hi
There seems to be an issue in UI7 using the Squeezebox device SetFileToPlay command, this does not work and I hear nothing.
On my old VeraLite UI5 I can create a scene and use the Squeezebox SetFileToPlay command and enter a URL like:
http://translate.google.co.uk/translate_tts?tl=en_gb&q=beer+assistant&client=t
When I run the scene the SqueezeLite instance says “Beer Assistant”
However when in UI7 if I create a similar scene using the same URL as above, it does not play and I hear nothing.
Looking at the LMS the difference seems to be that UI7 sends the URL differently and the & characters get changed to &
Can anyone else confirm, know how to fix ?
