I have a room with a GE / Jasco in-wall switch. It controls 3 GE / Jasco in-wall outlets with floor lamps plugged into the switched outlet. I also have to of the Aeon Labs remotes so that we can control the lights in this room independently.
RIght now:
Switch ON = All lights on
Remote, turn each light off (one at a time):
All lights off, switch still on
TO turn the lights on from the switch, I need to:
Turn switch off
Turn switch back on
Is there a way to program a scene such that when the last light gets switched off, the switch gets set to off?
[quote=“scottr, post:1, topic:197562”]I have a room with a GE / Jasco in-wall switch. It controls 3 GE / Jasco in-wall outlets with floor lamps plugged into the switched outlet. I also have to of the Aeon Labs remotes so that we can control the lights in this room independently.
RIght now:
Turn switch off
Turn switch back on
Is there a way to program a scene such that when the last light gets switched off, the switch gets set to off?[/quote]
should be pretty easy to do in luup. Create a scene that fires whenever any of the lamps gets turned off and then get the status of each lamp via a luup.variable_get and if they are all off set the switch to off. assuming your lamp devices are 20,21,22 and your switch is device 40
[code]-- this gets the status of the lamps, 1 is on 0 is off
local lamp1 = luup.variable_get(“urn:upnp-org:serviceId:SwitchPower1”, “Status”, 20)
local lamp2 = luup.variable_get(“urn:upnp-org:serviceId:SwitchPower1”, “Status”, 21)
local lamp3 = luup.variable_get(“urn:upnp-org:serviceId:SwitchPower1”, “Status”, 22)
– this checks if they are all off and turns the switch off
if (lamp1 == “0”) and (lamp2 == “0”) and (lamp3 == “0”) then
luup.call_action(“urn:upnp-org:serviceId:SwitchPower1”, “SetTarget”, {newTargetValue = “1”}, 40)
end[/code]
If the Switch supports power metering you can set there scene with the condition that if power readings drop to 0, then the switch it’s turned off and then on
